How to clean\polish rims. Ver. 1.0
I plan on doing the same with some amplifiers I just came across. Restoration is always a very rewarding process.
thatll be cake compared to rims, i would recommend gettin the speed ball because youll be able to polish that surface very easily, mainly flat. Just make sure to watch your drill. if it catches on a corner or curve it can kick the drill pretty good i hit my rim once and about killed somebody cause i was a dumbass //content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
I have a 10" rotary buffer for waxing etc... Think that'll work?
http://www.premiumautocare.com/ultimate-paint-protection.html > All //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Lasted on my Bonneville for over 7 months before the car was towed away to charity.
just bought two bottles and i did go get my third round of products, Noxon Metal Polish, Meguiars Hot Rims Polish, Eagle one Nevr Dull, and Nano Wheel Polish. //content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
Loooks like i have some work ahead of me
Well i finally got around to a test session. I tested everything on an untouched rim. No sanding , no previous polishing .
The Wheel of the test
close up
The products
From left to right the products are:
Mothers Metal Polish, Meguiars Hot Rims Mag& Aluminum Polish, Nevr Dull, Eagle One Nano Wax, Blue Magic, Noxon Metal Polish, and Mothers Powerball Aluminum Polish.
I then took a highlighter and marked sections for each product and used each per instructions
Here is after polish is on
After wiping the polish off here are the results of the seven products.
So after all the testing and products id have to say the best 2 products are Meguiars and Blue Magic with the Mothers in the can in second place. I still need to sand and stuff for the rims in the bad spots but as far as just polish goes those are my findings.
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
those center spots shine out pretty far enabling me to see well on the dark highways.
22
No Issues out of my CT Sounds amps..EQ, 6.5s. There is not one company out there that hast ever had a perfect QC run that I can think of.Hard to...
  • Locked
Mmats is sold. Open to offers on the Quart speakers and Kenwood HU. Matt
15
jeeper07
Rebuilding&Reconstruc ting
jeeper07
Indianapolis, IN
jeeper07
    May 24, 2024
