how to adjust crossover???
Italia30
6
NY
I have a Kicker ZX650.4 going in to Polk DB691, DB 651, and Polk Tweeters. I am new to this, Im am getting mostly midbass and highs,...no low end at all!!!!!........the amp has adjustments for XOVER-Hi-Low-Off(set to high), Input Level-Hi-Low(on Low), and X-Over Frequency 50-200 with four increments in between....any advice on how to set this up for a system without a sub???
2v preamp..........there is no full setting...just Hi-Low-Off--what should the crossover frequency be set to???
if you want full range sound frome your speakers, then set the xo to off.
with 2v pre outs, set the input to low.
if you want to hi-pass your speakers, set it to hi and set the xo fq to what ever sound good to you.
with the xo setting on off, you will not need to use the fq adjustment.
-vic
Italia30
Italia30
NY
thevic24
