looking for the perfect amp
I have a killer OS PPI that will destroy anything new in this pricerange. It is the PC2300, limited edition (white with black logo) it is the same topology as the PPI A1200.2. Look those up on Google. Read all the reviews on OS PPI amps..
I have a good feedback score on Ebay, 163 feedback 100% positive, all from used car audio. I also have quite a few other amps that I can sell you for cheap.
Are these dual 4 ohm? What are the recommendations on enclosure? What is the powerhandling?
i waiting on mine from rockford pm me if you wana buy it latest it will be here is the 10th
If you decide to step it up with your Mononblock, I have a Mmats D3500.1 that I am looking to sell. It almost matched the output of my Fosgate T30001BD without the current draw..
You have a 200 amp alternator, if your sub is dual 2 ohm and can handle 2000 watts rms, the amp does 2700 watts rms @ 1 ohm.. Stock charging system for normal music.
*woffer specifications*!
Mounting Depth 6.25"
Mounting Hole Diameter 9.25"
Motor Width 7.75"
Weight 31.5lbs
VC Diameter 3"
Magnet Weight 28.5lbs
Power Handling RMS/Peak 1000/2000
Impedance D 2ohm
Sd 314.00 cm²
Vas 27.40 L
Cms 1.99e-04 m/N
Mms 115.70 g
Fs 33.2 Hz
Bl 16.15
Re 3.60 ohm
Le 4.02 mh
Qms 5.15
Qes 0.43
Qts 0.40
Xmax 23.5 mm
Sensitivity 85.50 dB
Suggested Sealed N/A
Suggested Ported 1³ ft
Suggested SPL Ported 1.25³
witch amp for a good price ?
alexleon86
Benz
alexleon86
salinas Ca
alexleon86
