How should I run my subs?
brewski
I have a Rockford 200 watt 4 channel amp and 2 MTX 200watt RMS,4ohm dual voice coil 10 inch subs. I am going to run the amp 3 channels, 2 channels to my door speakers and 1 bridged channel to my subs. My question is, should I run just one of the subs or both subs in series?
Sadly, the amp only has enough power for one sub at a 4ohm mono load, if you series the 2 subs you will have an 8ohm mono load and your power output will be very low.
Hmmm... I was told that if I ran the subs in series off the one channel it would be a 2 ohm load and my amp manual says I shouldn't go below 4 ohm load with the mono channel.
"I was told that if I ran the subs in series off the one channel it would be a 2 ohm load"
No your getting it mixed up, parrallel will give you the 2ohms, series will give you the 8ohms.
Uhhhh, yall are forgetting about series/parallel wiring.
Dual 4ohm subs can be wired for a final impeadance of 4ohms
This way you would have a 4ohm final load for that one channel.
brewski
brewski
Sumner, WA
RandyJ
BP1Fanatic
BP1Fanatic
