How should i get my revenge?
Only thing I see wrong with that idea is.......the gun.....it`s gonna come back in your name
And the 'drugs' would cost a considerable amount...
I like the idea of a stun-gun to the antenna, to fry all the electronics in the car (if that in fact works).
That, plus a coupld cans of paint across the hood, should do the trick
in addition to the fiberglass resin, I've seen Marine quick set epoxy used to some success to weld one of the wheels from moving. They poured in and around the calipers, then covered the lug nuts so they couldn't be taken off and repaired.
Also, the U joints are a good culprit for this treatment, especially with a high driveline angle.
It's a difficult situation. I'd like to know what Decipah has up he sleeve.
shit in his gastank, then put some c4 on all his lugnuts and put it on a timer attached
to the ignition. So all his wheels fall off after driving for like 5 minutes
Or steal his car and remove the body and then return it later that day
imo, it should be as quite as possible...
1. resin/ hardner on every panel on the car-----paint job fu cked
2. get 1 gallon of your collected piss ( may take a week or 2)
and pour it on his seats and floorboard...-------interior fu cked
3. sugar in the gas tank...easy and quite...-------engine/fuel delivery fu cked
4. slash the sidewalls of the tires----tires ****ed
all quick and easy to do....
also, even if he has full coverage it would prob be considered a total loss by the insurence company....it would cost far to much to replace the entire interiour alone
This is all physical stuff; don't forget the mental aspect too. Do something like put a sign with skull and crossbones on it on his door and write "I'm coming for you." That will scare the piss out of him and he'll think about you as much as you thought about him. Also, don't let it be a one-time thing. Do something now, then a year from now, then 5 years from now. Or, just let it go...
Haha skull and crossbones!?? this isnt a cheezy horror flick! If you really want to make a mental impact put a few bullet holes in his front door...that will pretty much scare the shit out of him
x2, a good old shotcun blast into the drivers side window/door and into the interior after you jack everything in the interior worth a shit.... Through the drivers side window and into the instument cluster //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif That woud be wicked.
deadstealth
deadstealth
dallas
temperedcore
