how mcuh power
  • 2
whats size and watts (rms) on these speakers? the 6o5s are 90rms
if the others are lower 50 or so and their going in the rear run them off
the hu for fill. if they are the same it depends on how loud you want it
and how much you have to spend. you can go 50rms to 90rm
if the others are say 70 rms and you put 70+4 amp on them
the lower will sound louder than the 605s
go to a loucal shop and hear the 2 togther.make sure this doesnt
happen to you. ive seen this happen more than once
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
397
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
656
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
471
rngilman
rngilman
houston, tx
rsflores
    May 24, 2024
