How many XS POWER XP3000's do I need.
I have a CT Sounds 4000 and I have it powered by 2 yellow top optimas and the stock under hood battery. Im about to strap a second 4000 to it and move my two optimas under the hood. Ill be wiring three 15" mojo 5's to them at .66 ohms and I have a Singer 275amp alternator along with my stock 160amp delco. My question is how many batteries will I need in the back to support my amps and keep them in the high 13's on heavy bass notes ? I want to use the XP3000's with toolmaker buss bars. Any information would be appreciated.
Strap in at .66 will make each amp see .33 and I don't think those ct amps will like that very much... With those alts I have I'd want at least 5 31d in the back
I honestly didn't know that was how impedance worked on strapped amps. I thought they'd see .66 each. I guess I could run my dual coils in series then parallel the 3 subs for 2.66ohms giving each amp 1.33 ohms. Should still produce plenty of power for those subs. Thank you for that info !
Thanks man. I was looking for some kind of estimator like that. Appreciate it.
Np man..Good luck.
southpaw_inkz
southpaw_inkz
Buffalo, TX
illcustomz
