how many batts would i need to run a audiopipe ap3000?
is there any way if i have to many batts the alt could mess up?
Run two HC 2000 kinetik equivilent reserve batteries and a HO alt to keep them charged and you will be good. Don't listen to these ignorant azzholes that have never even used one of thess amps.
Havent used this exact amp but 3k is 3k. Just trying to help the man out. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i wouldnt recommend kinetik tho. my batt was cheaper and MUCH more powerful than a kinetik 2000....
We just got done with a system that has a kinetik KR5112 up front and a KR1212 in back on an AP 1800 and it doesn't dip under 12.5 on a stock alt also have another set up in a crx that has 2 apx 3500 on 2 HC2400. The crx has a bad head gasket so it doesnt get much play other than burps. Doesnt get listened to in a real sense either because the only speakers in it are subs.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
do i need a bigger alt or can i just use a couple batts? and what batts do you recommend? thanks,
I would say that if you are running a stock alt, you would need a couple big batts per amp. I had one on 2 C&D which is 270ah and I dont recall the cca's, but they seemed to do the trick. Demoing however drained them pretty quick....
So I noticed throughout this entire thread not one time was the rating on your alternator mentioned other than it's "stock".
Stock is a very vague word, I know cars that come with 80 amp alty's and ones with 140's
Clarify if you want a precise answer
car on or off?
babaganoush123
babaganoush123
chicago
mbrooky
