how many batts should i get for...
i should be able to use the 880 to cross it over right?
if you say so. sounds to me you have atleast a 4-way system with 10's, 6's, tweets, horns. this is your mess to figure out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
horns + tweets = same crossover point
6's + 10s = same crossover point
subs = same crossover point
_____________________________
= 3
interesting //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
what was the point now of getting 10's?
For once i am going to post a sensilbe responce in an eminence thread. I know, i know what is the world coming to, but if NG can do it, I guess i could as well.
I would shy away from the same crossover points for the diff woofers, unless you are cotjones, then go for it, but like its been said you will most likely run into some cancelation. i would skip the 10's, and just run 6's, or vice versa. Heck run more 6's to make up for loosing the 10's. or vice versa. same goes for the horns, and tweets, try crossing them over to play diff freq's. i think i remember you saying that your horns play up to 9k? so cross them over just below that, and cross tweets just above the horn cross, or find a midddle ground.
Power issue, you said you plan on running a separate power source @16 volt for the hk 4000's, so that is taken care of. for those amps you plan for the "front stage" a 200amp alt should do fine imo as long as you provide sufficient time to recharge batts after a good long time playing them at full tilt.
kevin
tweets will be in front cabin, horns will be behind the wall, no way there can be cancelation issues.
and with 12 mids and 8 tweets all in the small area of my 2 front seats, im not really concerned about cancelation lol.
i may get an external xover tho. ive had like 3 but my friend always takes them lol. i have a brand new legacy one now, donno if ill use it.
http://www.cardiscountstereos.com/catalog%20page.asp?Product+%23=LXR6
pimpedout97x
Tampa, FL
ngsm13
