2700 is so little granted you're probably not as active as i was in season.
one of my nutrition classes last year i had to figure it out for 2 weeks, i was averaging 4000 a day, and weighed a nice 150lbs, but working out 4-5+ hours a day helps out quite a bit too //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
but ive relaxed a bit over the past month or so, stuff like this makes me realize that when spring comes around and it warms up i need to start running alot more.
best of luck!
I feel great! I am in the best shape of my life at the moment and things are only getting better. I hear ya on the infomercials. Daily I hear stories about "hip-hop abs" //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif Little do they know that abs are made in the kitchen! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifShit, much better then those infomercials.. The only reason i havent done something like this is because im skinny as ****. haha I eat shitty too... but I by no means "feel" healthy.. I bet you do
just wondering but looking at your exercise routine....what does the units under the ab section mean....are you doing 100x3...just wondering....I think I'm gonna start a routine up...
Since you ride BMX I think squats and deadlifts would be in your best interest. This will give your legs even more strenght and your back will get stronger to sustain those landings.nice detailed routine... i dont do that much when i go to the gym but i have youth and good genes on my side aswell.... your routine is pretty constant from what i got form it did you run into pleatuing (sp?)? when i do my bench press i try and go for muscular endurance aswell as strength so for instance i start with 145lbs. and increase 10 pound for each set (10-8-6-4-2) then a burnout with 115lbs. and usually can do around 15- 20 reps.... i dont bother with my legs cause i ride bmx alot and they get a pretty good workout.... you should also try doing dips...
Congrats! I'll be doing some working out this spring/summer once the weather gets a bit nicer out and I cease using my weight bench as a storage shelf. I've gained 30 pounds in the past 4 years after starting a job stuck in a cubicle all day. Time to remedy that.
