how do i put the sub in the box?
anthonyfg
i bought an infinity kappa perfect 12.1 and a cheap box that is a little less than the manufacturer suggested dimensions. its 12 by 12 by 12 but a 1 inch slant, now im going to fill the thing will poly fill, but my question is how do i screw the sub on, what screws, do i remove the carpeting from where i attach it. the sub came with a gasket so do i put it on the rim and do i peel away the carpet or just stick it on the carpet, and do i also need to caulk it? thanks
i would suggest you trim the carpet by laying the sub in place and carefully cutting with a razor knife. use the gasket supplied by the manufacturer for an airtight seal. for screws use the thickest "wood screw" possible with nice wide threads and a pan head. use a screw that will NOT go all the way through the box material and make sure you drill pilot holes first.
I use 5/8 inch wood screws. The reason that I don't use anything longer is that the MDF may come apart at the hole if the screw is put all the way through the wood. The chance of this happening is minimal, but it's easier than having to repair MDF board.
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
511
I think he wants to use the existing enclosure he has, and its cut out for a single Ten inch sub at the moment
19
3K
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
anthonyfg
anthonyfg
san jose, ca
natem33
winkychevelle
    May 24, 2024
