how do i know if this is a wiring problem or a problem with the equpiment?
dellxps
ok so today i connected the wires from my new headunit to the wireharness specific to my car a 94 jeep grand cherokee ltd. as far as i know all of the color coded wires are connected properly. it snapped in to the factory wiring easy. but as soon as i turned on accessory and tried to get sound it didnt work so here is my question is there anything else i can do with the factory amp to get it to work or what did i do wrong?
So your getting power but no sound?
Also, is the harness you used have 2 plugs or 1?
If no power use a dmm to check voltage on yellow and red. Also make sure your ground is good.
If power is good and no sound make sure u connect the blue/ white from the deck to the blue on the harness.
If you have a stock factory amp you need to hook up the remote turn on to the blue wire in your harness or use the antenna turn on wire. You have to wake up the factory amp.
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
121
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
189
406
377
dellxps
dellxps
calgary,alberta
thorshammer1
audiobaun
    May 19, 2024
    May 19, 2024
