how can i run 2 amps
  • 6
Get a distribution block, run your power wire to it, then 2 power wires out going to the 2 amps. What kind of head unit do you have? If it has more than one set of rca outs, buy another set of rcas and run them to the new amp.
Something like this, with a set of main inputs that splits into sets of outputs for Front/Rear/Sub ..Line driver for bumping the outputs to 8vrms, which means little if any gain adjustment on the amps F/R fader and sub level control...oh, yeah, 7 band EQ too.....prices on these things range from 40 buck to whatever, depending on who made it and what functions you want...jus my .02
Precision Power PPI E.DZ 7-Band Dual Zone Equalizer EQ (EDZ)
Not sure but usually when a HU has only one set of RCA outs, it's a subwoofer out, probably how he has his mono amp hooked up. If it is internally switchable to a high pass, he could use it. This may suggest he needs a LOC before going into that PPI EQ
Thank you for that tidbit of useful info....which leads to the next question...what HU are you using, OP?
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
southport2014
southport2014
Indianapolis, IN
quackhead
Decebal
    Jun 10, 2024
