Hooking up my crossover power wire.
Yeah I would run it off your power dist block, thats easier than running a new wire. And if its got a 3a fuse already on the wire you are good to go.
Maybe you have no clue what you're doing?
- What HU/source are you using?
- What crossover do you have?
- What amp?
- What speakers?
- How is it all hooked up?
- What were you expecting?
HU: Pioneer avhp8400bh
crossover: Coustic 3 way crossover (no telling how old it is, probably 10years, which is probably the problem.)
tweet amp: alpine mrp300
component amp: sony xplod XM-GTX1852-FB-R
Speakers: 4 RF t1693 6x9s, 2 RF P1T-S tweets.
I have amps hooked to a distributor, which runs from a capacitor. I wired the crossover power in with my tweet amp at the distributor, and used a regular small speaker wire terminal on the ground wire and grounded it to the chasis (the small terminal maybe being another problem). The RCA cables from the HU runing into to the inputs on the crossover, and RCAs coming from output to amps.....
What was i expecting? To set my frequencies to my tweets and 6x9s...
By the way i have subs but waasnt running those to this crossover, my HU has one for subs.
Someone correct me if I'm wrong, I have never actually used a cap.
But you want the cap as close to the amp as possible. And generally you only need a cap for the sub amp. I doubt your mids draw enough power to need a cap.
HU: Pioneer avhp8400bhcrossover: Coustic 3 way crossover (no telling how old it is, probably 10years, which is probably the problem.)
Is the crossover the XM6? If not, what model?
The Alpine amp is 4 channel - are you bridging it to 2 tweeters?
The Sony amp is 2 channel - are you running the 4 6x9's as parallel pairs?
How do you have the crossover configured, and what settings are you using on the amps' HPF/LPF? They all play together. You're running an active system that can take a lot of time to dial in.
And the capacitor isn't your problem. Don't worry about that.
calebkhill
calebkhill
Phenix City, Alabama
calebkhill
