Honda Accord owners 1998-2002
what about volts like 13.2 or 14.4 cuz i wanna no if i need to do big three to get more power
Volts will very. Usually around 14. Yes you will need to the big 3. Yes you will most likely have to replace your stock alternator soon if running a lot of power. The stock delphi units are pretty notorious for being crap.
I've got my tweets in the pillar, and my midranges on the dash, where the factory tweets used to be. I went through two sets of pillars before I found a spot and angling that works for me.
As for the alternator, I've got the 4 cylinder that I've been told that the output is 105A. Mine is still stock, with 143000 on the odo. I've got two batteries, and a votage gauge that shows 14.3 at idle with the stereo on, but not jamming, and 14.4 without anything on. It's been a great car for me!!
wo! got pics of the mid setup?
id like to see that
I have a 95 Accord LX...
.. Do what I did: ( factory look )
... Comp. Woofer in the front door ( Factory position )
... Comp. Tweeter in the door ( Next to the door lock )
... Comp. Crossover inside the door, or whereever you feel like you want it.
* Required:
... 1" Hole Cut ( Depending on the size of the tweeter - I use 1" just for the simple fact that you can squeeze the tweeter in from behind, ( flush mount - without the flush mount )
... Just make sure when you drill the hole, put it in REVERSE, the drill, so you don't tear up the vinyl
coledawg
Where the Hell am I?
coledawg
Macon,GA
lashlee
    Jun 20, 2026
    Jun 20, 2026
