Hiss coming from speakers after amp install (help please)
  • 2
dls0680
Tampa
I have a pioneer 5 channel amp installed and when I have the music turned up to 9 or less it sounds perfect, crisp and clear. Once I get up to 10 or past I get a hissing sound. My stereo goes up to 60 but starts hissing at 10. I tried turning down the gains and that does not work. It still hisses weather I just lay music with the car on or off . I have my ground goes my to a bolt under my seat away from all other electrical. I used a grinder to grind the paint away to make it a good ground. Power wire is run on opposit side of vehicle from other amp wires but it only does it when it gets past 10. Any time read or suggestions ?
does it do it no matter what source u play?, could be rca/s.. do u have 3 sets rcas? play music unplug 1 set and so on see if noise is just on 1 set if so replace those.. some peeps need extra ground on amp and maybe even a 2nd 1 on hu..
I appreciate your response. I will give it a try tomorrow and see. I will post back my findings tomorrow evening
others my reply by them too.. pull rcas out of amp just put 1 set in at a time for front speaker see if only 1 set does it, if they all do it try them on rear speakers., if none do it on rear then something maybe wrong with front speakers, if only 1 set has noise thats the problem and either way this is easiest fix..
Yes i know that's what i was planning on. Unfortunately the rvca's are a little difficult to gain access to. My other thought was to wrap a wire...
Can you running optical into that Bit processor? Your main input for noise is going to be between the Bluetooth and the processor. If you have...
Just when you think you're humming along... and... hmmmm happens!
22
Decibels are a measurement how loud something is...it's not the frequency of hearing...
19
dls0680
dls0680
Tampa
BOOMINGRANDPA
    May 16, 2024
    May 16, 2024
