Highs and mids dropping out
Easy. Check all the connections. Or it could be too low of a load for the stock amp. But it's probably a bad connection.
Well it did it even before i touched any audio parts its like it had an eq that at high volumes lowerers the mids and high but leaves the bass so it doesn't blow speakers and my father has the same truck and it dose the same thing im wondering how to disable this
Replace the factory head unit or deal with it seems to be your options.
Ah I thought you meant they where completely cutting out.
Yeah most cars do that. Mine does also but my DSP overrights it. That's really the only way. Get a DSP that will DE-EQ and allow you to write your own curve.
Ah I thought you meant they where completely cutting out. Yeah most cars do that. Mine does also but my DSP overrights it. That's really the only way. Get a DSP that will DE-EQ and allow you to write your own curve.
Ahhh i see thats what i was looking for awesome ill start looking for one thanks for the help
samuellinn
samuellinn
Victoria
Papermaker85
