I need amp this size for m'y fi ssd d1,the cresendo cost to me about 200$ more.
Maybe in the futur i will upgrade for xcon!
Hifonics or cresendo ?
Thank's
Thank's
I would go with crescendo out of the two.but before all that look into incriminator audio amps.I need amp this size for m'y fi ssd d1,the cresendo cost to me about 200$ more.Maybe in the futur i will upgrade for xcon!
Thank's
Yes i see every Day on the classifieds but my problem is important not in usa (canada)The Crescendo is obviously going to be better, but you're going to pay a lot more.
Incriminator makes great amps, but I would not pay retail for them. You can find better deals out there dollar per watt
I say look for used stuff in the classifieds. I'd rather have a solid used amp than a new "budget" amp for the same price.
Just my two cents
I'd run the older brutus amps if I was doing a cheap build without a ton of electricalstay away from Hifonics...its Maxsonic dirty power garbage ...
Then you should have never looked at hifonics in the first place. Other stuff to avoid, belva, audiopipe, shark, soundstream etc.. Neither of those are efficient. Zues series from hifonics is absolute sh*t just barely above boss and pyle.I realy like the clipping light on remonte of the cresendo,i want good quality amp for my boat and the more efficient as possible !
Did they make a 2k brutus amp that did over 2k?I'd run the older brutus amps if I was doing a cheap build without a ton of electrical
