Hifonics Brutus BRZ 1700.1D
f1mclarenagr
4SKN
220
Milwaukee
Perfectly Mint Condition.
10/10 functionally
10/10 cosmetically - Some paint missing where screws go. However when you screw it down, the new screws will cover this up.
Was used for about four months to power two Type aaarrrrgggghhhsss. It was screwed down the entire time and nothing was allowed in the trunk so no scratches are present on it at all! Fed 14+ volts (monitored with voltage meter) as I only set the gains for 1200 WRMS.
- 200 + half on shipping.
- Would look into trading for Hertz HSK 165 XL + cash on my end
- Not looking for other subs or amps
- Check my eBay feedback to know I am legit.
Brutus Series Monoblock Class D Car Amplifier
RMS Power Rating (@ 14.4V):
4 ohms: 600 watts x 1 chan.
2 ohms: 1200 watts x 1 chan.
1 ohm: 1700 watts x 1 chan.
MOSFET power supply
Wired HFR-3 remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +10 dB bass boost at 45 Hz)
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
4-Way System Protection circuitry (thermal, overload, speaker short and DC protect)
Heavy duty aluminum alloy finned heatsink for maximum heat dissipation
Silver-plated unbalanced RCA level inputs
Silver-plated molded screw terminals
Input sensitivity:
Input Level (Unbalanced): 0.2V-9V
Input Level (Balanced): 0.04V-8V
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic filter (15-35 Hz, 24 dB/octave)
Phase Shift: 0-180°
Damping factor: >290
Frequency response: 35-250 Hz
CEA-2006 compliant amplifier
Dimensions: 16-15/16"L x 9-1/4"W x 2-7/16"H
2-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
View attachment 26523884View attachment 26523883View attachment 26523885View attachment 26523886View attachment 26523887
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
f1mclarenagr
4SKN
f1mclarenagr
Milwaukee
f1mclarenagr
    May 16, 2024
    May 16, 2024
