HiFonics amp Question
They have a new Goliath Ga series for 2018 Amplifiers | Hifonics
And a new Bxx series BRUTUS BXX Amplifiers | Hifonics
They still don't make the specs clear if its RMS or Peak watts.
If you click on any of the pics show, scroll down to see the specs and also the wattage the amp does. It's def rms. And for their pricing, forget it. I'll stick with a brand that will do at least rated for either same or cheaper $$. peak watts means nothing....continuous aka rms is what you wanna look for. Peak just means for a few seconds whereas rms is every minute/hr of listening.
Only the super amps put the RMS in the specs. all the other amps they don't make it clear if there numbers are RMS or Peak
temporary hosting photo
here they saying the new GA5000.1D is 2500 watts but the specs say 5000 x 1 @ 1 ohm
the company can claim all it wants, Every certified test of hifonics on the amp dyno has always been a horrible failure. Their track record is beyond garbage, idk why people still buy into them. You arent buying hifonics, you are buying Maxxoniccs AKA Crunch and Autotek. Hifonics died a long time ago. Maxxonics is just dressing up its corpse and earning money doing freak show street performances with it.
looks like BXX line and super amps use RMS in the specs and the GA series amps use Peak. The brutus elite line just have some stupid number. They do not make it clear on the packaging, user manuals or hifonics site if they are using peak or RMS numbers.
The hercules uses peak numbers in the specs. The way they rate there amps is a total mess.
looks like BXX line and super amps use uses RMS in the specs and and GA uses Peak. The brutus lines just have some stupid number. They do not make it clear on the packaging, user manuals or hifonics site if they using peak or RMS numbers.
yeah looks like the better ones do about 1/2 of what ever it says, if u know that going in and get it used for cheap not bad but i would pay over $150 for any hifi idk how they sell the $300+ ones
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
Amp
144
gallileo60
gallileo60
Gulf Coast of Texas
gallileo60
Brendon Jenness
    May 8, 2024
    May 8, 2024
