Help with voltage
  • 4
Because the voltage does what it wants and I would like to keep my voltage steady full tilt lol
If you are referring to an aftermarket amplifier power source, it's not controlled by the PCM. Wiring is direct from the battery to amplifier. The amplifier controls the power. Your stereo control the signal to the amplifier, and the PCM controls the signal that turns the radio on. Not sure if it controls the power or signal output of your stereo.
Let us know more about your setup, so we can provide more accurate advice.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
447
I was thinking 2 aught wire an do you think it would help if i took the secondary battery ground ran it through the ground sensor an tied the...
currently I am using 4g wires for my ground and power (1-1.5ft for ground and like 16ft for my power) and no I did not sand the area for the...
91
deehorton1989
deehorton1989
Durant, oklahoma
    May 19, 2024
    May 19, 2024
