Help with my setup! PLEASE!
+ to + - To - on each sub , then + to + from one sub to the amp ,same with the -. then the same with the other sub
Does it matter which negative to negative? Each sub has 2 positives and 2 negatives?
---------- Post added at 06:10 AM ---------- Previous post was at 06:09 AM ----------
I have seen all the diagrams, there not helping me, unless you made one specific for my subwoofer and amp, thank you.
This is how it is currently set up.
You have it wrong. The +/- terminals on the amp are just paralleled internally. Do it like this...
[sUB#1_VC#1_minus] to [sUB#1_VC#2_minus] to either [AMP_minus]
[sUB#1_VC#1_plus] to [sUB#1_VC#2_plus] to either [AMP_plus]
[sUB#2_VC#1_minus] to [sUB#2_VC#2_minus] to either [AMP_minus]
[sUB#2_VC#1_plus] to [sUB#2_VC#2_plus] to either [AMP_plus]
Each sub's VCs are in parallel to give 2 ohms, then the amp terminals connect the subs internally to parallel them down to 1 ohm.
Make sense?
//content.invisioncic.com/y282845/emoticons/thumbcool.gif.25d3f515a7f948dd6be51428263071ef.gif
Search it on YouTube. "How to wire 2 dual voice coil 4ohm subs to 1 ohm."
I know how to do that... I am just confused in my specific case. Please just tell me if that new diagram I put up in my last comment is correct and don't tell me to look it up.
DangerCDV
DangerCDV
Canton, GA
DangerCDV
