fire919
Hello all,
...i want to use 0 gauge primary with 250a inline
opt1. If nonfused dblock used, i will connect both amps with a 4gauge reduced at end of 0 gauge
opt2. If fused dblock used, i will use 150a|60a fuses (ph4000-md|mrx-v70 respectively) and connect amps w/ 4gauge wire.
Are any 'opt' right? which is best?...is there a better way? thanks
FYI
Stock Electrical
110a alternator
wired down to 1ohms
ph4000md
Micro Technology Amplifier
1 Ohm Stable Class D Mono Block Amplifier
Rms at 1 Ohm: 2000 Watts
MAX at 1 Ohm: 4000 Watts
Frequency Response: 10Hz ~ 220Hz
Input Level: 5V ~ 0.2V
Variable Subsonic: 10Hz ~ 50Hz
Variable Low Pass Filter: 40Hz ~ 220Hz
Switchable Bass Boost: 0dB, 6dB, 12dB
Fuse Rating: 150 Amp
Dimensions (Inches)
Height: 2.12
Width: 5.51
Length: 13.42
mrx-v70
Amplifier Specifications
Amplifier Class D
Number of Channels 5
Total Peak Power Output 1200 watts
Total RMS Power Output 600 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power .02%
Speaker Level Inputs Yes
Preamp Outputs No
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 50 - 400 Hz
Low-Pass Crossover Frequency 50 - 400 Hz
Subsonic Filter 5 - 30 Hz
Signal-to-Noise Ratio 87 dB
Bass Boost 0 - 12 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 30A x 2
CEA-2006 Compliant Yes
FYI
Stock Electrical
110a alternator
wired down to 1ohms
ph4000md
Dimensions (Inches)
Height: 2.12
Width: 5.51
Length: 13.42
mrx-v70
Amplifier Class D
Preamp Outputs No
High-pass (HP)
Fan Cooled No
Fuse Rating 30A x 2
