Help With My First System
it will be hard to keep it under 450 for subs and an amp unless you get used ,but dc lvl 3 subs or american bass woofers American Bass - XD 1044. 125 each.as for the amp , the alpine is decent still
Okay well I suppose I could spring for a JL Audio with 300 RMS, but I can't afford anything above a 300 RMS Alpine amp. Would 150 RMS per woofer be able to power them adequately? :\
If you have 2 subs with single 4 ohm coils, you want your amp to do rated power at 2 ohms, not 4. Not sure what amp your looking at exactly, but it's something to check into.
Hmm, I'm looking at a 1000w Peak Alpine amp that runs 300w @ 4 Ohms, 500w @ 2 Ohms.
So you're saying in this instance, my best pick is 2 subs running 250 RMS @ 4 Ohms each?
You are fine if the amp is 2 ohm stable, as that will be the load you are running. As long as your amp settings are done correct, you should be set with the gear you picked.
Justin Watts
It's Amateur Hour.
Justin Watts
Pleasanton, CA
naughtyca
BP1Fanatic
BP1Fanatic
