Help with enclosure modification
  • 5
Nosferatu333
Sup fellaz,
I have a q-logic dual 10 inch enclosure that measures .65 cubes per sub. I need it to measure .525 per sub (Boston Pro .5's)
I plan on placing 2x4's cut to length to drop down the cubes. I have already figured out the lengths i need to drop it to the desired size.
My question to you guys is if im correct in my logic.
I used the formula to calculate internal volume: HxWxD divided by 1728. I plugged in deminsions of 2x4's until i obtained the difference between .65 and .525. I plan to add that difference in 2x4's in the enclosure to drop the total cubes.
Is this a sound plan. I know it may sound confusing but if there are clarifying questions please ask.
If im incorrect in my thinking please correct me.
Thanks to all in advance.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
Nosferatu333
Nosferatu333
Northern California
azimuth
