Help with a Box
NYTROOPA
I plan on buildin (actually my father will) a box to house 3 10's and their recommended volume is 1 cu. ft.
1. What is the best material to use to build a box?
2. What does it mean when it says the speaker is best sealed? Does it mean no ports mounted on the outside, or does it mean mounted on the inside(so the speaker is inside the sealed box?
3. So it's better if you could go like 1.2 cu. ft. per sub?
The material of choice for sub boxes is Medium Density Fiberboard (MDF, also called Melamine), 3/4 inch thick.
A sealed enclosure means no air leaks of any kind behind the speaker. No unplugged holes, no "ports", no gaps in the wood joints.
Going +/- 20% different than the recommended volume makes little difference. In general, bigger gets you lower frequency response and smaller gets you tighter sound quality.
NYTROOPA
NYTROOPA
Syracuse, NY
NYTROOPA
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
