capthooklv
I bought a power Acoustik 10farad cap that had no manual and i have a couple of questions i need help with. This hybrid has terminal labeled positive and negative input/output. Is this wired right?
Positive input: comes from #2 battery with fuse between
Positive Output: goes to amp positive terminal
Negative input: comes from grounded chassis (all 4 amps and #2 battery grounded in same location)
Negative Output: goes to amp ground wire terminal
remote: is the switch that when powered turns on cap
