Help wiring hybrid capacitor.....
  • 6
I bought a power Acoustik 10farad cap that had no manual and i have a couple of questions i need help with. This hybrid has terminal labeled positive and negative input/output. Is this wired right?
Positive input: comes from #2 battery with fuse between
Positive Output: goes to amp positive terminal
Negative input: comes from grounded chassis (all 4 amps and #2 battery grounded in same location)
Negative Output: goes to amp ground wire terminal
remote: is the switch that when powered turns on cap
back when... I read something about having to use a charge card with the capasator before hooking it up directly to 12v positive...
but nobody realley cares.
because nobody uses cap. here. they are a waste of power that cost money.
This is in a 2002 Ford F250 crewcab. I have a battery isolator going to a deep cycle battery with 600cold cranking amps then to fuses then to these amps-
mids & highs 2-Orion 2100(2x100watt rms @4ohm)
1 pair Kenwood 6.5" componets with tweets in front column, 1 pair Polk 6x8 in rear
midbass 1-Orion 1200d (1x1200 rms @ 1 ohm)
2-Alphasonik 10" dual 4ohm vc in sealed box at .7 cubic ft under rear seat
bass 1-Orion 2500d (1x2500 rms @ 1 ohm)
1-Eclipse 15" titanium dual 4ohm vc in slotted box 5cubic ft tuned to 31hz in bed of truck (right now I am planning on a shell but may do a cut through into cab)
Will just the battery be enough for this? this is not for spl just my weekend vehicle and proud of it.
I think a battery will be just fine for your application but It would be better to give us the Amp Hours AH instead of the CCA. youre not running a ton of power and Ive seen people run more than that with one battery (aka me lol)
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
677
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
capthooklv
capthooklv
Grand Junction, CO
capthooklv
