HELP! what do i need...
basswiigee
MICHIGAN
i plan on running 4 12in 3013ps @ 1 ohm off a powerbass xa1500...
i have a 140amp alt [stock]
zero gauge power and ground
12gauge spk wire
an optima yellow top
batt. is located in trunk so a short run...
will this electrical system support that set up?
big 3 and you'll be ok , but i'd get a better batt
hey... lol just bought that like 2 months ago, 05 cobalt, that battery is almost too big...
---------- Post added at 10:54 PM ---------- Previous post was at 10:54 PM ----------
suggestions
12gauge spk wire
Get the Big three done in 0ga, and I think you may be fine/border line depending on what vehicle it is, and stock amperage alt you have.If you havent bought that optimus batt yet..FYI I recommend a different batt.I had 4 BNew Redtops dump on me last summer as well as runining an expensive alt in the process due to the batts.Look at an XS, or DieHard Plat,Odysee,Orileys Super Start plat AGM, Dekas,ect
^^^^^^^this ^^^^^^^
trying to figure out whst the big 3 is... and yellow top is AGM batt. with advanced spiralcell, i got 0gauge ground and power, what else? is my spk wire good? maybe goto 8ga?
the big 3 is a wire kit battery power to alt power ,ground battery to frame and battery ground to body
I was and still am a old school CD type of listener. Pio always had great CD players and fairly good TA/EQ options, got familiar and you know what...
37
653
719
956
basswiigee
basswiigee
MICHIGAN
jasonbillnelson
    May 16, 2024
    May 16, 2024
