HELP!!! Weird sound from speakers when using 3Sixty.2!!!!
  • 4
Well if everything is fine without the unit, then it seems that the unit is causing the noise.
If ground/power, voltage, all the wiring is correct, and the install of the dsp is correct, there shouldn't be a noise.
Brand new things can be defective though. I order some speakers a month ago and they came in defective. It happens.
maybe someone more familiar with dsp's can give you some more info though.
One could also possibly try to put a filter on the power input and see if you can get rid of it that way.
I miss hawaii //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I also just checked the voltage and the voltage on the amp in 12.85 and the rest of my stuff like my lc2i and remote out wire is 12.10. could that...
61
221
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
657
408
DropDownLowYota
DropDownLowYota
Honolulu, Hawaii, United States
CrossoverOre
    May 18, 2024
    May 18, 2024
