HELP!!! Weird sound from speakers when using 3Sixty.2!!!!
Well if everything is fine without the unit, then it seems that the unit is causing the noise.
If ground/power, voltage, all the wiring is correct, and the install of the dsp is correct, there shouldn't be a noise.
Brand new things can be defective though. I order some speakers a month ago and they came in defective. It happens.
maybe someone more familiar with dsp's can give you some more info though.
One could also possibly try to put a filter on the power input and see if you can get rid of it that way.
I miss hawaii //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
DropDownLowYota
DropDownLowYota
Honolulu, Hawaii, United States
CrossoverOre
