Help to find the correct amplifier for my subs
What is your budget?
Will you have line-level inputs or speaker level inputs to the amp?
Any specific questions? Favorite brands? Favorite shops?
well for budget, I will spend from $200 to $400,
I want to shop in best buy, and I want to have a quality brand. What brand do you recommend for car audio systems?
well for budget, I will spend from $200 to $400,I want to shop in best buy, and I want to have a quality brand. What brand do you recommend for car audio systems?
dont go to best buy for your amp ,they are still pricey for what they have .what you need is an amp that does 1000-1500 rms at 1 ohm.you'll then wire yur sub at 2 ohms and get half the power from the amp ,and it leaves room for another sub if you want down the road. 200-400 is a decent budget for an amp in that power range if you want new ,then look at american bass ,aq,a dc 1.2 ,or cresendo amps
Iwant to connect the subs in bridged mode but I get confused with all that RMS stuff... so I want your help and support to find the model and brand of the amplifier...
I found this amp... Jl Audio Jx500/1d Mono Subwoofer Amplifier - 500 Watts RMS X 1 At 2 Ohms is that good for power up my subs?
http://ecx.images-amazon.com/images/I/71jTOAIHj7L._SL1046_.jpg
If you want to run 2 of those Alpine speakers, like mylows10 said - find an amplifier that will put out enough RMS power for two of them, or maybe even a little more. You've got a great budget for that size of an amp, so your window is pretty wide. Find an amplifier that is rated at 1000 or even 1500 watts RMS at 1 ohm, if you're going to be running a pair.
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
871
Dayton would be a really nice choice as well as the SQL. I would look at a R. Sounds sub too https://www.resilientsounds.com/product-page/gold-15...
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
Dcast91
Dcast91
Eagle Pass Tx
CrossoverOre
    May 16, 2024
    May 16, 2024
