Help, subs playning real low
DDSC
Wang-aholic
Ok heres the deal, dont give me any shit.
Now, I have 2 12" Dual whathe****s single 4 ohm with a Soundstorm Labs 2channel amp:(
Anyway, having the crap that I do I shouldnt haveto say that Im not satisfied with how loud it is so I decided to build a new box to replace the bandpass box it came with, so I built a 2cube box tuned to 35hz,
got the box built subs wired the same way they were before except with solder connections instead of crimps and installed and when I turned the radio on they are playing quite a bit lower than when they were in the bandpass and I dont know anything that could be wrong with them
On a side note I had to ghetto rig my rca's by cutting the head off and splicing a good one on there because I broke the post, the amp was attached to the box which I forgot when I went to take the old one out and when I pulled on it one of the RCAs bent and broke, so I took one of my HT rca's and cut the head off and spliced it on by twisting and electrical tape.
HELP ME!!!!!! it was OK before but this is just unacceptable
set your gains properly?
never changed any settings and it sounded fine before
the amp is shit get a new one
I said dont give me any shit, and your saying that like the speakers are good
I dont think the spekaers like the box I switched em back and its sound better again, anyone wanna buy a box for 60
are you saying they aren't as loud?
"lower" does not mean quieter, it means lower.
if they aren't as loud, its because the box isn't peaky like the old bandpass box was.
They arent as loud
BP box was probably peaking much higher...
the bandpass box picked up everything even, the lows played just as loud and clear as the highs did :Duntil it got turned up to high, and then everything distorted pretty even:crap:
I found out its the rca, if I fade the speakers to the left I still get bass but when I fade it to the right the bass is gone, after I put the subs back in the old box which means I wasted time taking those out as Im gonna have to put them bacl in when I get the rcas:verymad:
Anyone got a set of rcas up for donation to get my back to norm if I can get the money for shipping, Im broke:(
haha your a bitch crying over your shitty system
he only said to get a new amp hahaha
and you have two subs??? that box is for one...
DDSC
Wang-aholic
DDSC
Jackson, MI
konechiwa
michigan born
    May 14, 2026
michigan born
    May 14, 2026
