HELP! sub not doing anything! (pics)
all i did was connect the two reds, and two blacks and run one of each speaker wire to the speaker wall terminal. their sadered and have electric tape
okay thats not good....... seems like u really dont know what ur doing
like i said, disconnect the speaker wires from the amp. Then measure the resistance at the speaker terminals on the box. Also turn the gain on the amp all the way down. It's probably going into protection from clipping
so ur doing this one?
What's ur amp, or its ratings?
ur settings are set too high, when u had it before at 32v on the speaker terminals it was the max ur amp was gonna push out. If u changed ur bass boost it send ur amp into protect. My advice, is to check ur speaker terminals on the box with the DMM like i told u to earlier (3rd time btw) and make sure its measureing the right impedance, its still possible that maybe ur connections weren't 100% connected.
also, i just connected the ground wire from the amp directly to the neg terminal on the battery, so it cant be ground problem now, or an amp problem. soooo, the only possibility now is rca cables?
Maybe I missed something here, but should you have your groung wire attached to the chassis or frame of you car? Not running your ground wire from your amp to the battery?
ok, i got it working now.
BIG thanks to all who tried to help
there was something wrong with the posts i attached to the speaker wire ends on the inside of the box. i got them changed and its running strong now.
thanks again
perfecxionX
perfecxionX
indianapolis
phyphoestilic
