HELP! sub not doing anything! (pics)
perfecxionX
im doing my first install on my first system, and i apparently did something wrong. My amp lights up as if its getting power but the subwoofer makes no sound.
i have an alpine cda-9856
profile ap1000m
audioque sd2.515
knukonceptz amp install kit, and 12guage speaker wire i got at lowes
http://s126.photobucket.com/albums/p116/perfecxionx/?action=view&current=IMG_4092.jpg
http://s126.photobucket.com/albums/p116/perfecxionx/?action=view&current=IMG_4094.jpg
http://s126.photobucket.com/albums/p116/perfecxionx/?action=view&current=IMG_4093.jpg
http://s126.photobucket.com/albums/p116/perfecxionx/?action=view&current=IMG_4095.jpg
please help me, this project has taken me over a week now, and i really want to get this figured out.
Pic's no worky!! For your situation, I'm not real sure what your problem is. Do you know for sure the amp is in working condition. Mine did somthing like that a while ago, I took it apart and found that it was blown. Hope this helps a little...
Jon
I had a similar problem, make sure you have a good ground. I didn't have a solid ground on mine and it would light up and not make any sound.
Also if you have a bass boost knob make sure it's not broken, my subs were really quiet even with the boost turned up and I when I shook the knob it would start pounding.
I had a similar problem, make sure you have a good ground. I didn't have a solid ground on mine and it would light up and not make any sound. Also if you have a bass boost knob make sure it's not broken, my subs were really quiet even with the boost turned up and I when I shook the knob it would start pounding.
had the same problem as that when we installed my system.
No sound is coming out the subs?
did you turn on subwoofers from the HU? go into setup/audio/subwoofers/on
did you turn your subwoofer output to +15? go into mode/mode/mode, until you get to level.... turn the knob all the way up to 15......
yeah thats what I said
also, i just connected the ground wire from the amp directly to the neg terminal on the battery, so it cant be ground problem now, or an amp problem. soooo, the only possibility now is rca cables?
perfecxionX
perfecxionX
indianapolis
phyphoestilic
