phyphoestilic
Liquid Fire...
no, if the speaker termianls are reading 32v then that means the RCAs are giving the amp a signal. It's probably somethign with the sub, check to make sure u wired it correctly. Or just test the resistance at the box's speaker terminals and see if it actualy gives the correct ohm reading.also, i just connected the ground wire from the amp directly to the neg terminal on the battery, so it cant be ground problem now, or an amp problem. soooo, the only possibility now is rca cables?
