help newbie with gauge sizing
banks8604
Lets say that I have a MTX JackHammer JH404 amp for my interior speakers and a MTX XThunder 1000XD amp for my sub, what gauge should my power wire be if Im using a distribution block with 4 gauge outputs to hook the 2 amps to? Do I even need a distribution block? What size inline fuse should I use?
Thanks in advance
Most likely, 4 awg will be enough, if your length is less than 12' - I consider you to be in the 90A range in the table below. If you are more than 12' then look at 2 awg or 0 awg. The inline fuse is sized for the wire. If you want to have one power wire ran to the back, then split to two amps - you'll need a way to do that safely - that is where the distribution block comes in. If the wire size in is the same as the wire size out - you don't need a fused distribution block. If the wire in is larger, then you want fused so you protect the smaller wires.
Visit this page and read it (provides fuse sizing):
FUSES
That is exactly the info I was looking for. In the wire chart is the amperage your total peak of the amps or RMS?
I was going to run a 10' run of 2g to a dblock into (2) 4g runs to the amps. According to the fuse explaination I should be good with a 200 amp fuse for the 2g and then run a 125 amp for the (2) 4g after the dblock, is that correct?
Here are the two amps I will be running:
JBL GTO14001 - Monoblock Car Amplifier, Power Amp - Sonic Electronix
MB QUART DSC4125 1000W 4-Channel Amplifier: VMInnovations.com
I think I like that MB Quart 4 channel. Since I've joined the forum, Ive noticed alotta people use them. If the table is rms, I think I should run 2 gauge to a dblock and then 4 gauge to the amps
banks8604
banks8604
E O N J
keep_hope_alive
