Help New to installing amp setups. Wiring front Speakers to amp 4ch????
DAT-GANGSTARR
7
Hi
Heres my sound system setups... i need help i got my sub hooked up and everything, but i want to add an amp to my front speakers will help it sound better and keep up with my sub. the prob is i dont know how to hook up the wiring to my 4 ch amp. im a noob w/questions.
my setup..
Head unit - Kenwood KDC-X696
Front door speakers - Fronts 6 1/2 KFC-1694PS kenwood door speakers•
specs RMS: 140 watts per pair / 70 watts each
infinity tweeters mounted on door Idk what model quite old with infinity crossovers??? specs idk.
Rear speakers - Kenwood 6 1//2 KFC-1694PS
Sub- Alpine Type R single 12 inch. powered by a TMA amp 500watts.
4 channel AMP- Alpine MRP MF240
Bridgable
RMS Power at 2 Ohms
50 W x 4
RMS Power at 4 Ohms
40 W x 4
Performance
Frequency Response
20 Hz - 20 Hz
Signal to Noise Ratio
100 dB
THD at Rated RMS Power
0.08 %
Crossover / Equalizer
Bass Boost
With Bass Boost
Bass Boost Frequency
50 Hz
Low - Pass Frequency
80 Hz - 80 Hz
okay i want to power only my front speakers total of four. i already installed the alpine 4 ch. amp but not the speakers. i hooked up a single rca says- fronts. but not hooked up wires.
my kenwood door speakers are 4 ohm and one tweeter idk... how much power will i get to my speakers each infinity tweeter idk specs??
for one side door do i use the crossover box and use one single wire to my amp. or use seperate kenwood speaker and seperate infinity tweeter to amp? do i use the crossover for my kenwood speakers?
and how are the alpine amps are they good, will my setup sound good? i need help thanks.
how do i hook up my front speakers to my amp what would be best..
im a total noob please help me...
Run separate wires from the Kenwoods and tweeters to the amp. Kenwoods off one pair of channels tweets off the other pair, with the crossovers. You don't need crossovers for the 3-ways. Use 'Y' cables to connect the front RCA's to both sets of amp channels.
heres the pic for the setup please help me im still confused where it goes on the amp..
Ill try and lend my hand as I dont you are getting the correct answers, yet. It looks to me like your running passive, which is easier, less processing.. but if you arent then dont follow any of the install ahead.
This is for a PASSIVE set-up.
So, left (driver side door) Wire positive and negative wire of component speaker to indicated spot on crossover, on same side. Then, do the same for the tweeter wires. Now, there is a power ( positive and negative) wire on the crossover. These wires lead all the way to the amp terminal channels. Specifically wire the front driver side to the 1st channel. In parrallel ( i believe, or Positive of crossover to positive of amp terminal channel and then, obviously, negative of crossover to negative of amp terminal channel. Now, AGAIN, these should be on channel 1. Now passenger side, do the same as said above, but wire crossover power and negative wire to amps respective 2nd terminal channels.
RCA's from hu to amps rca input (channel 1 and 2).. one thing to keep in mind is to make certain you designate the color wire to its respective (left or right) side and match on amps input rca terminal..
Active 3 way.
Never done this before, so be skeptical haha. But i believe you just take postive and neg wires from all speakers and tweeters directly to amp.. but furthermore, ask an expert haha
That should do it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif now make a solid ground.. hope this helps bro, if not keep posting questions!
From your diagram -
A - left tweeter - ch1 speaker
B - right tweeter - ch2 speaker
C - left kenwood - ch3 speaker
D - right kenwood - ch4 speaker
RCA left to both ch1 and ch3 input
RCA right to both ch2 and ch4 input
gain for channels 1+2 will control tweeter level
gain for channels 3+4 will control kenwoods
From your diagram -
Okay thanks i wired the setup like u said thanks.
DAT-GANGSTARR
DAT-GANGSTARR
Hi
DAT-GANGSTARR
