OP
Paradigmonds
- Thread Starter
- #16
OK, to give you guys an update.
Yesterday, I left work early and went by my local audio shop. Talked with a guy there and bought a RF 0 ga IN // 0 ga OUT inline fuse holder along with a 250 amp fuse.
Went home and installed the 0 ga power cable, with 250 amp inline fuse holder. Ran that to the fused distribution block, which has the two 60 amp fuses, then to the amps.
Also, sanded paint away and installed a 0 gauge mounted ground bracket. Ran the 0 guage ground wire through a distribution block and to the two amps.
So, here's what happened:
At first, the RF 600-4 ( running the four - 6.5" mids ) started working fine, but no sound coming from the Kicker ( which is on my tweeters ) Checked and saw that the distribution block fuse had blown going to the Kicker amp. So, checked all of my connections, grounds, over once more. Checked the 250 amp fuse at the battery and it is fine. Then, changed the 60 amp fuse in the distribution block, start her up again and Kicker amp starts smoking. Turn off and disconnect, but its probably toast.
So, I disconnect everything, go through the process of making sure that everything is connected tightly, fuses are all good, and everything is good to go.
So, I've still got my RF 600-4 hooked up and I take a RF 250a2 to hook up to my tweeters. Hook it up, start up the car, and suddenly I'm getting what sounds like bad ground loop noise. Turn it off and re-check everything again.
Start up again and nothing. No lights coming on on either amp. Checked inline and distribution block fuses and they are fine. So, I take the DMM and check voltage at the battery ( 13.1 ). Then check voltage at both amps ( 13.1 ). So, there isn't a problem with the voltage dropping.
At this point, I am really at a complete loss. I'm pretty sure I killed the Kicker amp, and I'm worried that unless the RF amps have an internal fuse that I may have wasted both of them, as well.
The cable that I was running from the Distribution block to the amps was 6 ga. I was wondering if that cable was not large enough, but neither of the amps could take anything any larger.
I'm really just lost at this point. I've hooked up dozens upon dozens of amps before, for myself and friends. I've never had problems like this before.
Obviously this all started when I put in the new alternator and new battery, but I'm not having problems with any other aspect of my electrical system. No other blown fuses anywhere, everything working fine. No electrical problems whatsoever................just apparently frying amps like a short order cook.
Any more suggestions?
Thanks for taking the time to keep up with my posts and offer guidance. I really appreciate it.
W
W
