Help..........new battery and alternator and now I'm blowing fuses like crazy
Not sure how that could be considering it left him stranded on the side of the road lol useless info yes.. I agree
except the OP didn't get left stranded, someone else in the thread did. Try and keep up please.
OP you have either a short in the wire, or a short in the amp(s)
Sorry I didn't get to explain further, but wanted everyone to know that the problem is now solved.
OK, so when the problem started, I'm assuming it occurred because of the new battery/new alt and the wiring couldn't handle the voltage. Went back and checked the wiring that I pulled out when I put in the 0/1awg and found a tiny area where possibly the wire was nicked and it had melted. It was actually rather difficult to see, but definitely there. So, there never was a problem with the battery or alternator...........just a short in the power wire.
Now, onto the Kicker amp that started smoking after the power wire change. I'm not sure if that wasn't a problem with the amp itself. I haven't changed anything since that amp went up in smoke and all of the other amps are working just fine.
I took the Kicker amp apart and there is actually just one MOSFET that has some blackening area around it. It really doens't look that bad at all. However, when I hooked it back up just to see if it would work, I got the Protection Light and nothing else.
So, thats where I'm at. Glad to have gotten past those problems. Now, you'll see me asking a bunch of questions about mid-bass and 3-way components, as well as which brand of subwoofer provides the best mix of SQ and moderate SPL, should I so desire to let loose a little boom now and again.
Thanks for all of your help, guys.
Have a good one!
P
Paradigmonds
Baton Rouge, LA
whitemax
