You are right - I was wrong
2) Input Voltage Range: A wide range of signal
input voltages can be accommodated by
the 1000/1v2’s input section (200mV – 8V).
This wide range is split up into two subranges, accessible via switches located in the
“Amplifier Input Section” of the amplifier.
The “Low” position on the “Input Voltage”
switch selects an input sensitivity range
between 200mV and 2V. This means that
the “Input Sens.” rotary control will operate
within that voltage window. If you are using
an aftermarket source unit, with conventional
preamp-level outputs, this is most likely the
position that you will use. The “High” position
on the “Input Voltage” switch selects an input
sensitivity range between 800mV and 8V. This
is useful for certain high-output preamp level
signals as well as speaker-level output from
source units and small amplifiers. To use
speaker-level sources, splice the speaker output
wires of the source unit or small amplifier
onto a pair of RCA cables or plugs or use the
JL Audio ECS Speaker Wire to RCA adapto
