Sweet!..You went with the big boy amp. The ZED's are beasts. Just about nothing you can't do with them.
Yeah I can't wait //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Quick question about the B2, It's got dual power and ground inputs, which I'm not to familiar with. Looking at the diagram in the manual it shows running two seperate power wires up to the battery. Should it be ok to just use my single 1/0 lead from the battery and then Come out of a distro block close to the amp. also If I do that should I have a fuse in each of wires leading to the amp or is the one fuse in my main cable enough?
Maybe I could just put an AGM battery beside the amp and run both supply leads off that.
