Help me pick an amp for my PSI platform 2 10'' 2ohm subs
the dc 2k is a nice amp. wired to .5 each sub would probably get close to 1k depending on ur rise. but i would look into a 4k amp if the subs are rated for 1500 a piece.
Have you ran it stable at .5 only specs I can find on it go down to 1ohm
it would prob do close to 3k @.5. I've only clamped it wired to 1. PM me if you are interested.
---------- Post added at 12:17 AM ---------- Previous post was at 12:16 AM ----------
the DC site ''recommends'' a second battery to run that.. Is that going to be necessary for me to push this much power safely or can I get away with just 1 good one?
I run 1 extra 102 ah batt and my voltage is great.
what size is ur alt? i would recomend a second bat in the back. you wont have to worry about voltage drop much then. i sent u a pm to by the way
The sky is the limit on budget... you should NOT be looking to run an amp at .5. That shit is for poor people.
Look at the B2 Audio Zero5. Or Zero1 if you want some headroom.
Tnx I'll check them out. And yeah I want something thats going reliable and not to be to hard on things
You guys are quick !!! lol I'll check out all those . need to bounce for an hour or so but I'll be back.
Thanks I think I'm going to like this forum //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
If you are not new to Car Audio and money is not hindering you from performance, then you know what I am about to show you...
WoofersEtc.com - C51700D - Crossfire Monoblock 1700W C5 Series Amplifier x2 strapped @ 2ohms..I know you said space is an issue, but personally, I would rather use 2 bulletproof amps than one of lesser build quality stretched beyond it's rated limits..
WoofersEtc.com - Leviathan III - ZED Audio 6-Channel Amplifier if you know Car Audio, then I need not explain.
just my .02
AbbaZabba
AbbaZabba
Alberta, Canada
AbbaZabba
