Help me pick 2 amps
or since he is only running 3 speakers in the smaller car, why not go with the best 3 channel amp out there:
Phoenix Gold Octane
Frt / Rr
2 ohm Per Ch. 200 x 2 -
4 ohm Per Ch. 100 x 2
Section Sub section
4 ohm Mono - 400 x 1
Actually what im going to do is run components in the doors, I may either go with coaxials or 6 1/2 midbass speakers in the panels behind the front seats, and i'm gonna run about 200-250 watts to each voice coil in the 10w6. With that, I need an amp that puts out roughly 200-250X2 channels and another that puts out about 150X2 channels.
Originally posted by spraydformula Actually what im going to do is run components in the doors, I may either go with coaxials or 6 1/2 midbass speakers in the panels behind the front seats, and i'm gonna run about 200-250 watts to each voice coil in the 10w6. With that, I need an amp that puts out roughly 200-250X2 channels and another that puts out about 150X2 channels.
ok that helps and if you would probably want to go matching amps here is an idea:
for the sub at 250 x 2 @ 2ohms and if you ran another at 4 ohms for the components it would do you 125 X 2 @ 4 ohms
Originally posted by limitkid7 i know a guy that has 2 pg octane amps
I know a guy with a 73 gremlin,
basically how are the new PG's??????? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
spraydformula
spraydformula
Franklin, Wi
denim
