Help me pick 2 amps
or since he is only running 3 speakers in the smaller car, why not go with the best 3 channel amp out there:
Phoenix Gold Octane
Frt / Rr
2 ohm Per Ch. 200 x 2 -
4 ohm Per Ch. 100 x 2
Section Sub section
4 ohm Mono - 400 x 1
Actually what im going to do is run components in the doors, I may either go with coaxials or 6 1/2 midbass speakers in the panels behind the front seats, and i'm gonna run about 200-250 watts to each voice coil in the 10w6. With that, I need an amp that puts out roughly 200-250X2 channels and another that puts out about 150X2 channels.
Originally posted by spraydformula Actually what im going to do is run components in the doors, I may either go with coaxials or 6 1/2 midbass speakers in the panels behind the front seats, and i'm gonna run about 200-250 watts to each voice coil in the 10w6. With that, I need an amp that puts out roughly 200-250X2 channels and another that puts out about 150X2 channels.
ok that helps and if you would probably want to go matching amps here is an idea:
for the sub at 250 x 2 @ 2ohms and if you ran another at 4 ohms for the components it would do you 125 X 2 @ 4 ohms
Originally posted by limitkid7 i know a guy that has 2 pg octane amps
I know a guy with a 73 gremlin,
basically how are the new PG's??????? //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
176
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
532
375
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
364
spraydformula
spraydformula
Franklin, Wi
denim
    May 16, 2024
    May 16, 2024
