HELP: Installing HU
Rell
Asked on another forum and really no help at all, searched on here and nothing came up so now hopefully one of you guys can help me out.
Having problems with my 87 caprice. Been trying to get this Sony HU installed. I already took out the factory stereo that was working fine by the way. I bought an wiring harness from ebay which comes to find out does not plug into my factory harness so I dont have to cut it... Nothing plugs into it.
So I cut the factory harness and tap into it and directly wire the harness for the stereo directly to the factory car haness and I get no power. So I take the stereo and wire it up to the cars battery and I get power to the stereo. I checked all the fuses under the dash and on the HU and all of them are good. Anyone have an idea whats up or what I can do?
If nothing works Im selling this HU and just buying an new one, which I really dont want to do right now since this one was free.
Yeah,
I did the following and no power when I put the key in.
Constant 12V+ Orange to the HU yellow
Switched 12V+ Yellow to the HU red
Ground Black to HU black
hmm..well im not sure, but like i said, if its working at the battery then its your car/wiring/fuse, and not the headunit so buying a new one wont fix the problem. Might be better to take that money and take the car to a shop and have them install it, probably around 50-60 bucks.
I was thinking maybe it was the Constant 12V+ Orange which I think is the battery wire. Maybe something sparked or touched each other where I pushed the HU back in and turned the key.. But if that was the case then Id have an blow fuse some where right? which I dont seem to have cause I checked all of them.
also check to see if the HU is getting a solid ground. I had that problem in my car with my hu. I had everything hooked up correctly and it turned out to be a bad ground to the HU.
Rell
Rell
on the couch
Steven206Seattl
NorthFramingham
    Jun 30, 2026
