Help! HT Sub Box Build & amp!
Torgus
Maxima.org
What box design should i use for these 12s?
I have 2 12'' RFR 1812 that are used.
http://www.fortunecity.com/skyscrape...f/rfr1812.html
Model RFR-1812
Description 12" Punch Power Woofer
Nominal Impedance 8 ohms
Re
(DC Resistance) 7.08 ohms
Power Handling
(RMS/Peak) 600/1200 W
Sensitivity 88.0 dB
Fs 27 Hz
QMS 3.24
QES 0.51
QTS 0.44
Sd
(Cone Area) 83.71 in2
Vas 3.5 ft3
Xmax 0.4 in
Voice Coil Diameter 4 in
Mounting Depth 5-19/32 in
(14.21 cm)
This is going to be a HT box.
I was thinking 7 cubes tuned to around 15hz? does that sound about right? or should it be around 20-25? also how large should the port be? any advantage to 1'' MDF? less box flexing? Should i make supports in the box as i'v seen other do to stop flexing?
Also i would need an amp to push them. does anyone have any suggestions? it looks like i need around 1200rms @ 4...
I'm hoping these will be extremely loud...thoughts?
oh and to finish the box i figured some textured dark grey spray paint and some rubber feet. i'd like to make the box into the coffee table but if i mount glass above it will it shake like crazy?
bizump 38 views and none has any input???
i think i found an amp for it tho. $320 shipped and it should do 1400 @4 x1 which is good because until today everything i found was over a grand for that output.
i'm going to make a hinged faceplate for the front where the subs will be. easiest way i can think of doing it and slightly protecting them...thoughts?
Torgus
Maxima.org
Torgus
Boston
Torgus
