I Cant Decide
DonH
Ok i have a problem i want to upgrade again. I want to run an 18 because there so darn bad *** looking. SO here is the thing i want to keep the amp i am running right now which is a Fusion PP-AM2000.1 which is capable of running at .5 ohm and can easily at 1 ohm. It is rated at an underrated 1200 RMS @ 1ohm. With that said...
I cant decide on what 18 to run. I know 1200 isn't allot bu it sure can push an 18 I know that. I Cant decide between a Fi BL18 (maybe BTL) with all the options or an IA Death Penalty. what should i get??? also what bat should i snag up?
thanks
-Don
thanks
-Don
if you are running only 1200 then you need to stay away from a btl, you do not have enough power. it needs ateast 2000rms. get a BL it will take the 1200 like a champ
Reading>You, he said BL
edit: Reading>Me, he said maybe BTL
all these **** options i just cant decide!!
also do you think one bat in the back suffice?
lol.. i used to think like that. then i just started buying and testing out because you'll probably never have the same setup for more than 6 months to a year with new subs and styles always coming out. the 1 and only 18" ive had so far is a soundsplinter rlp. i had it in a 5.6cf box tuned to 30hz in my extended cab on my old SAZ1500. it sounded awesome, but could of used a much bigger box to pound the lows, probably 7cf or so. thats all i would have changed with that setup
theres no way to determine bro...
find a sub that will like 1200-1500rms and go from there.
testing and expermenting is the best way to learn in CA.
true dat looks like im going to be surfing the web tonight
DonH
DonH
So Cal
WOT
BP1Fanatic
BP1Fanatic
