Help Choosing the correct Amp for a SA-12 D2 sub
  • 4
JordE
NYC
hey guys I'm looking for some advice on an amp purchase for a SA-12 D2
currently i'm looking at the following:
SAZ-1000D
SAE-1000D
SOUNDSTREAM P1.1500D
Hifonics HFi1500D
Hifonics Brutus BRX1200.1D
gonna attempt to build the sub box from 3/4 excel plus mdf..(more dense than regular mdf) using Sundowns specs ( 1.5-2.0 ft^3 @ 35hz)
I'm thinking of wiring the Sub for 1ohm... what would be the optimal setup/amp/wiring to get the most out of my sub
any help/input would be greatly appreciated
Ported Enclosure Build...........work in progress
Get the saz 1000. Best option
One more quick question....what about the Sundown SCV-1500D...would that be overkill for one sub?
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Rockford has low sensitivity and Xmax compared to the sundown and the big fancy looking basket is just there to hide the pansy @ss motor thats inside. The price is ridiculous for what you are actually getting, mainly a sub for show, sundown will definitely get louder based on design and build quality. In the 350$ category, look up HDC3 12 or Dss Ethos 12, or tantric HDD. You'll need a bigger ported enclosure then the one you are building now.
Rated power output
3000W x 1CH
1500W x 1CH
400W x 1CH
That would be fine
right now i'm running a Fosgate T0D412 on a Power T500-1bdCP............wired at 2 ohms in my 2010 Edge..it hits ok and I get the lows....but I know I can do a lot better
I've heard some impressive sound from JL w7s...but those are waaaaaaay out my budget...
the SA-12 seems like a beast for that price....just trying to decide what would be my best option for powering it without killing my wallet
Same price as an SCV 1500.1 but more power
Q1-2200D
Step up in the subwoofer class if you want to see big improvements
HDC3.112 Copper Coil Subwoofer
Make sure you do the big 3 upgrade and get some agm batteries for your battery bank.
T500-1bdCP
300 Watts x 1 @ 4-Ohm
500 Watts x 1 @ 2-Ohm
500 Watts x 1 @ 1-Ohm
wouldn't that be under powering the sub?
T500-1bdCP 300 Watts x 1 @ 4-Ohm
its temporary till you get the next amp. It would give you a good idea of how much more power you'll actually need depending on how much the sub is actually moving in your enclosure.
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
978
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
Not at all, amplifiers have gain control to attenuate the output to safe levels.
I've moved this post to installations. Can't work out how to delete it here.
JordE
JordE
NYC
HomeGrown
    May 16, 2024
    May 16, 2024
