Help Choosing the correct Amp for a SA-12 D2 sub
JordE
NYC
hey guys I'm looking for some advice on an amp purchase for a SA-12 D2
currently i'm looking at the following:
SAZ-1000D
SAE-1000D
SOUNDSTREAM P1.1500D
Hifonics HFi1500D
Hifonics Brutus BRX1200.1D
gonna attempt to build the sub box from 3/4 excel plus mdf..(more dense than regular mdf) using Sundowns specs ( 1.5-2.0 ft^3 @ 35hz)
I'm thinking of wiring the Sub for 1ohm... what would be the optimal setup/amp/wiring to get the most out of my sub
any help/input would be greatly appreciated
Ported Enclosure Build...........work in progress
Get the saz 1000. Best option
One more quick question....what about the Sundown SCV-1500D...would that be overkill for one sub?
Rated power output
----RMS power, 2 ohm linkable/dual mono
3000W x 1CH
----RMS power, 1 ohm mono
1500W x 1CH
----RMS power, 2 ohm mono 800W x 1CH
----RMS power, 4 ohm mono
400W x 1CH
Rockford has low sensitivity and Xmax compared to the sundown and the big fancy looking basket is just there to hide the pansy @ss motor thats inside. The price is ridiculous for what you are actually getting, mainly a sub for show, sundown will definitely get louder based on design and build quality. In the 350$ category, look up HDC3 12 or Dss Ethos 12, or tantric HDD. You'll need a bigger ported enclosure then the one you are building now.
Rated power output
3000W x 1CH
1500W x 1CH
400W x 1CH
That would be fine
right now i'm running a Fosgate T0D412 on a Power T500-1bdCP............wired at 2 ohms in my 2010 Edge..it hits ok and I get the lows....but I know I can do a lot better
I've heard some impressive sound from JL w7s...but those are waaaaaaay out my budget...
the SA-12 seems like a beast for that price....just trying to decide what would be my best option for powering it without killing my wallet
Same price as an SCV 1500.1 but more power
Q1-2200D
Step up in the subwoofer class if you want to see big improvements
HDC3.112 Copper Coil Subwoofer
Make sure you do the big 3 upgrade and get some agm batteries for your battery bank.
T500-1bdCP
300 Watts x 1 @ 4-Ohm
500 Watts x 1 @ 2-Ohm
500 Watts x 1 @ 1-Ohm
wouldn't that be under powering the sub?
T500-1bdCP 300 Watts x 1 @ 4-Ohm
its temporary till you get the next amp. It would give you a good idea of how much more power you'll actually need depending on how much the sub is actually moving in your enclosure.
JordE
JordE
NYC
HomeGrown
